Home Forums Products Stompboxes Connecting H9 with other pedals Reply To: Connecting H9 with other pedals
#145122
gkellum
    Euripides wrote:
    Just in case, however, how do you think I should tackle this issue should it rise? Should I use them all via the FX loop to avoid it or should I do something different?
    Well, I'd probably arrange things as I'd ideally want them and see if any problems arise.  But it could be you might need to try a few different permutations out just to be sure how you'd ideally want things anyway.
    In any case we assembled a lot of information about the Pre / Post functionality in this help video:
    https://www.eventideaudio.com/support/downloads/setting-prepost-routing-options-h9
    But as you mentioned, people were able to make good use of all the effects in the H9 before the pre / post feature, and maybe, you won't need or want that extra complexity.
