Home Forums Products Stompboxes One H9 preset is bypassing??? Reply To: One H9 preset is bypassing???
#145174
gkellum wrote:
If you save a preset in bypass, then when you load it with a MIDI program change, it will load bypassed.  So, activate it and resave it.  That should fix your fix problem.
I did try that and it didn’t work. I saved a different H9 preset in that location on the Boss which works fine. I’ll try creating a new one on the Boss with that H9 preset and see what happens.
