Home Forums Products Stompboxes H9 Expression and Tap Switch Y Cable Setup Reply To: H9 Expression and Tap Switch Y Cable Setup
#145206
Given To Fly
    nickrose wrote:
    Given To Fly wrote:
    nickrose – I quoted these two parts from the technotes. Would an ideal expression pedal for the Factor Pedals and the H9 be a pedal with a 10k potentiometer and a single TS output?
    j
    25k is more common, and is OK. Single TS output avoids the 0-100-0 issue. So, you are not wrong …
    I’m ok with not being wrong. 🙂
