Reply To: Control an H9 with a Factor pedal’s knobs
Home Forums Products Stompboxes Control an H9 with a Factor pedal’s knobs Reply To: Control an H9 with a Factor pedal’s knobs
#145238
You want a regular MIDI cable, which is a 3 or 5 pin DIN cable, available on line or from an electronics shop (they are used for audio as well). Connect it from the Factor's MIDI OUT to the H9's MIDI IN. The plugs should look like one of the pictures below.
DIN 41524: 3-pin, 90°, 180°DIN 41524 / IEC/DIN EN 60130-9: 5-pin, 45°, 180°
