Home › Forums › Products › Stompboxes › Connecting via iOS devices (problem with iPhone 7+) › Reply To: Connecting via iOS devices (problem with iPhone 7+)
No, I don't think turning the H9 off will make it harder to connect to with another device, but what I personally do when I want to switch from one iOS device to another is I press the X, Y, and Z switches simultaneously on the H9 twice. Pressing these switches toggles Bluetooth off and on, and it usually works fine to do that to break an existing connection. I also do that if I'm having trouble connecting to an iOS device as a first step. As a second step I might reset the H9's system settings by restarting it with the right footswitch and HOTKNOB switch pressed (the one in the upper left hand corner of the H9). That takes care of any pairing problem I might run into 95% of the time.
