Home Forums Products Stompboxes Pitchfactor MIDI pass through and amp change commands Reply To: Pitchfactor MIDI pass through and amp change commands
#145381
Nick – I do have the MIDI set to THRU – to make sure I understand, are you saying that the current firmware is the issue and will be fixed in the next release? If so, do you have any sense of when the next release will come out? I’m new to MIDI, so another question – do I need to set the channel for MIDI receipt on the Legacy 3 to a different channel than the PitchFactor? I have the G-System set to transmit on Channel 1, the PitchFactor to transmit channel and receive channel 1, and the Legacy to receive on Channel 1.
Thanks again,
Paul L
