Reply To: Timefactor system problem
Home Forums Products Stompboxes Timefactor system problem Reply To: Timefactor system problem
#145411
gkellum
Ok, what if you start the TimeFactor with the middle footswitch pressed?  Does it turn on with UPDATE on the screen? If so, try connecting it to your computer and seeing if the updater will recognize it.  Reinstalling the TimeFactor software using the updater might help.
If that doesn't work, unfortunately I think you'll need to send your TimeFactor in for repair.  To do so, you'll need to write support@eventide.com.  You could link to this thread in the email, and they'll send you the information you'll need.
