Reply To: How to tap tempo from an external midi controller to 2x H9’s ?
Home Forums Products Stompboxes How to tap tempo from an external midi controller to 2x H9’s ? Reply To: How to tap tempo from an external midi controller to 2x H9’s ?
#145438
Sounds like you need a better controller ..
One option would be to use a single physical switch to drive both of the H9's in parallel, as long as you avoid ground loops.
