Home Forums Products Stompboxes How to tap tempo from an external midi controller to 2x H9’s ? Reply To: How to tap tempo from an external midi controller to 2x H9’s ?
#145448
Just discovered that activating Tuner through midi CC follows the same behaviour… I have to tap 4 times to activate and then deactivate it (instead of more usable and intuitive 2 times).
Maybe you could consider making H9 to respond to 0-63 values as well… i don’t think it would interfere with controlers that send only 64-127 values for CC numbers for momentary actions. Please consider suporting this function for other parameters as well in your next firmware update, if possible 🙂 Thank you in advance.
