Home Forums Products Stompboxes POP sound when switching presets routed pre+post to post+post Reply To: POP sound when switching presets routed pre+post to post+post
#145477
I don’t want to push on this, but do you (Eventide) have an answer to this POP sound? Otherwise, PRE/POST feature is useless and not usable.
I want to use EQ/Compression in front of preamp and use Delay after preamp on a preset, but I cannot switch back from other preset where both H9’s are routed POST, whithout getting this loud POP. It’s loudnes is proportional with signal level. Basically, this cannot be used in a live situation.
I don’t even want to try a noisy Sculpt or Crush algo routed PRE (where they’re supposed to be) and then discover the hugeness of an even louder POP, when I switch from timebased presets routed POST.
