Home › Forums › Products › Stompboxes › H9 Ignores Preset Range When Using MIDI Footswitch › Reply To: H9 Ignores Preset Range When Using MIDI Footswitch
#145523
panthalassa
    nickrose wrote:
    I’m not sure if I quite understand – preset range is more of a display function to limit the number of presets that are visible or can be stepped through.
    With MIDI, you control both the MIDImap, and the actual Program Change you send, so it would seem irrelevant.
    Thank you for your reply. I don’t think it’s irrelevant when. I do not have control over how many programs I switch through. Now, on the H9, I can step through the preset range I set without a hitch. When I try to do the same on another MIDI switcher, I scroll right past my set preset range regardless of where i set it. I hope that is clearer now.
