Reply To: H9: how to simulate Dunlop Q95 wah [engage/effect/disengage] with midi-expression pedal?
Home Forums Products Stompboxes H9: how to simulate Dunlop Q95 wah [engage/effect/disengage] with midi-expression pedal? Reply To: H9: how to simulate Dunlop Q95 wah [engage/effect/disengage] with midi-expression pedal?
#145547
michaelboe
dedeman wrote:
H9 – Is it possible to [activate] a midi-loaded preset [Q-wah algo] with a midi-expression pedal?
Scenario:
1. From a midi controller, a program change is sent to a H9 which loads a Q-WAH preset, but inactive (bypass) – that I can do already;
2. Pressing the expression pedal – connected to the midi controller – from zero towards max value should: a) activate the wah preset, b) variate the assigned parameters
3. Reverting the expression pedal to 0-10 range would return parameters to zero and deactivate de Q-WAH preset (bypass).
Basically, simulating a Dunlop 95Q wah? This wah has a spring that puts back the pedal in zero position when stepping off and disengages the wah effect with a microswitch.
https://www.sweetwater.com/store/detail/SP-H9?adpos=1o1&creative=103263529321&device=t&matchtype=&network=g&product_id=SP-H9&gclid=Cj0KEQiAzZHEBRD0ivi9_pDzgYMBEiQAtvxt-JIc7TsvIWg-4uypnDPIGJct2Ze9oA6NIkeWeat5-coaAul18P8HAQ
