Home Forums Products Stompboxes H9 Preset Weirdness Reply To: H9 Preset Weirdness
#145624
uskillbotics
    Hi Eventide! I can reproduce this issue.
    Using:
    1. H9 Max (v. H9_5.4.0[0])
    2. iPhone with iOS 10.2
    3. H9 Control 2.7.8
    Repro steps (assuming paired H9):
    1. Tap Lists > [Name of H9]
    2. Tap a preset to select it
    3. Tap More > Delete preset > OK
    Expected results:
    1. All presets above the deleted preset should have moved down one slot.
    2. The last slot (99) should now be empty.
    Observed results:
    1. GOOD
    2. The last slot (99) retains its preset, AND the slot below it (98) now contains a copy of that preset as well.
    Notes:
    You can repeat this process as many times as you want. That means If you delete preset #1 ninety-nine times, you will have ninety-nine copies of preset #99. If I had to guess (knowing absolutely nothing about the app internals), it looks like the app is copying presets down a slot instead of moving them.
