Home › Forums › Products › Stompboxes › H9 as a MIDI Controller › Reply To: H9 as a MIDI Controller
        February 12, 2017 at 7:07 pm
        #145748
You can use the AUX switch to increment or decrement the current preset (see UM p.34).
As long as you avoid ground loops, you can use a single AUX switch to control 2 H9s, so it sounds as if what you want is possible.
