Reply To: Pitchfactor won’t connect to H9 software or updater!?!
Home Forums Products Stompboxes Pitchfactor won’t connect to H9 software or updater!?! Reply To: Pitchfactor won’t connect to H9 software or updater!?!
#145865
Lerxst77
Hi Gkellum,
 Finally got it to connect! Thank you!
I followed the link you provided. The only thing left to try was to change computer…got no luck there!
I then tried to pair it with midi cables to my modfactor…didn’t work?? So I tried the same with a firewire external sound card and Voilà!!
Then while updating… ”an error occured” … pitchfactor wrote ”BAD !!” .  At this point, I had tried everything to reinstall any firmware and would never get more than 33% completed!! . The Pitchfactor couldn’t even boot. It either crashes 1 sec. after startup or I hold the middle footswitch to update mode.
I went back to the forum to figure this out and found that other users were having the same problems.
https://www.eventideaudio.com/community/forum/stompboxes/pitchfactor-stuck-update-mode-cant-update-either-direct-updater-or-update
After reading post #11 by Stringbot, I wanted to try on my other computer ( both running Windows 7 pro) but it is not firewire and I knew I couln’t get it to connect. So my last resort at that point was to at least try with a standard usb cable. And to my surprise, the Direct Updater detected it right away.
I then started updating to the latest firmware no problems! It turned out that the problem was caused by my computer the whole time. The funny thing is that I don’t have any problems with my modfactor stompbox connecting to my main computer while the pitchfactor still can’t.
In conclusion, always try it on another computer.
I hope it helps other users!! Thanks
Lerxst
