Reply To: Expression pedal problem with H9 – 0 to 86 to 0?!
Home Forums Products Stompboxes Expression pedal problem with H9 – 0 to 86 to 0?! Reply To: Expression pedal problem with H9 – 0 to 86 to 0?!
#145872
Please see other posts on the Forum, such as:
https://www.eventideaudio.com/community/forum/stompboxes/h9-expression-and-tap-switch-y-cable-setup
Basically, your problem is that this pedal expects a TRS lead – if you use a mono lead, you get the 0-100-0.
