Home Forums Products Stompboxes Expression pedal problem with H9 – 0 to 86 to 0?! Reply To: Expression pedal problem with H9 – 0 to 86 to 0?!
#145874
    msurys wrote:
    Thank you! Is it TRS that should connect to output/input of the pedal, or just TRS from exp/aux output of the pedal to H9?
    The TRS is for the pedal – the H9 does not care. Note that you should set the H9 EXPTIP for EXP only – it gets complicated if you want pedal and switch with this pedal.
