Home Forums Products Stompboxes Expression pedal problem with H9 – 0 to 86 to 0?! Reply To: Expression pedal problem with H9 – 0 to 86 to 0?!
#145881
    The conclusion of your arithmetic is correct.
    One thing to consider is that the three switches are actually a special case of two switches (switch 3 is based on holding down both the others), so you can't just sacrifice one of them in exchange for a pedal.
    Note that also using both a switch and a pedal on the H9 requires specific and correct wiring. See elsewhere for information.
