Home › Forums › Products › Stompboxes › Need to mimic EXP input expression pedal with midi expression pedal › Reply To: Need to mimic EXP input expression pedal with midi expression pedal
March 10, 2017 at 4:55 pm
#145909
In the H9 Control application:
- Pedal icon
- Assign MIDI CC messages to pedal functions.
- Set expression pedal value (aka Hotknob value).
- Select from MIDI CC 0 to 99 or Pitch Bend.
On an H9/Max/Core:
- Press & hold Hotknob + Tap switches.
- Dial to MIDI. Press Hotknob switch.
- Dial to RCV.CTL. Press Hotknob switch.
- Dial to EXP, flashing on left. Press Tap switch.
- Dial among MIDI CC 0-99 or BND.
On an older stompbox [PitchFactor]:
- Press & hold encoder switch + Tap.
- Dial encoder to MIDI. Press encoder switch.
- Dial encoder to RCV.CTL. Tap enocder switch.
- Dial encoder to PDL < arrow flashing left. Press Tap.
- Select among C0 to C99 or BND.
