Home › Forums › Products › Stompboxes › H9 MAx does not recognize audio input › Reply To: H9 MAx does not recognize audio input
#145912
gkellum
    There are a couple of different ways to reset an H9's settings.  Could you turn it off and then turn it on with the right footswitch and the big, black wheel pressed?  It should say "Initia" on the display.  It would be good to double check and make sure that it was fully returned to its factory settings…
