Home Forums Products Stompboxes Change from preset numbers to bank numbers in preset list – HP control Reply To: Change from preset numbers to bank numbers in preset list – HP control
#145972
gkellum
    stevthac1969 wrote:
    Newbie here.  I created a preset list in HP control for my TimeFactor pedal.  I now realize that I didn't set it up to show the preset numbers as banks.  Is there anyway to change this retoactively, or do I need to start over?
    Well, H9 Control doesn't give you a way to change this once you've created a list.  You could go into the file system and change the preset list's setting file directly if you wanted.  On Mac all of H9 Control's preset lists are in your home directory under ~/Library/H9 Control/PresetLists and on Windows they are in your home directory under AppData/Roaming/H9 Control/PresetLists.  You would need to open the metadata.tidel file for your preset list in a text editor and change:
    "list_has_banks": false
    to
    "list_has_banks": true
