Home › Forums › Products › Stompboxes › H9 Max – won’t update + no algo errors › Reply To: H9 Max – won’t update + no algo errors
April 2, 2017 at 8:55 pm
#146048
You don’t warranty pedals that are used with other power supplies…I assume that means you don’t warranty many pedals at all then?
The Strymon Zuma is certainly not underpowered…it’s 500ma per output. That matches the spec you require in your spec sheets/manual?
