Home › Forums › Products › Stompboxes › H9 Max – won’t update + no algo errors › Reply To: H9 Max – won’t update + no algo errors
#146049
Sorry if that last message came across as sharp…I’ve had a long day!
Are you saying that if I connect the H9 power supply to do the update, that should work, and then I can use the Zuma for general operation? (Albeit without warranty)
The Zuma is advertised, as are the Voodoo Labs supplies, as being more than capable of running the H9.
