Home Forums Products Stompboxes Aux switch for Restart of H9 Harpeggiator? Reply To: Aux switch for Restart of H9 Harpeggiator?
#146322
camn
    Ha. I have homemade switches :). But its a momentary normally open.
    Lets run through a couple things, find the problem.
    Tell me this- what kind of cable are you using- mono or stereo?
    And then lets confirm your settings:
    Pedal–>general settings–>UseExpPedal/Aux/Both–: Set to AUX.
    Pedal–>AUX Switch Mappings–: confirm your switch is assigned to “Performance Switch”.. and more importantly.. confirm it is NOT set to anything ELSE. I suspect it is ALSO assigned to “Set Parameter 9” (or 10)
    Check those- let us know.
