Home › Forums › Products › Stompboxes › The new PitchFuzz algorithm is available for the H9 now! › Reply To: The new PitchFuzz algorithm is available for the H9 now!
May 16, 2017 at 1:49 am
#146386
hlaricca wrote:
The update is failing both from a computer and ios device. It starts, but then there is always a connection error after a few percentage points of the update being transferred. It sometimes even fails while it is clearing up space for the update.
You're trying to install the update using Bluetooth? There's a known issue where this can happen using some iOS devices to update an H9. Could you try to update using USB instead from your computer?
