Home › Forums › Products › Stompboxes › The new PitchFuzz algorithm is available for the H9 now! › Reply To: The new PitchFuzz algorithm is available for the H9 now!
The update is failing both from a computer and ios device. It starts, but then there is always a connection error after a few percentage points of the update being transferred. It sometimes even fails while it is clearing up space for the update.
You’re trying to install the update using Bluetooth? There’s a known issue where this can happen using some iOS devices to update an H9. Could you try to update using USB instead from your computer?
I fixed it by forcing both the mac and ios device to completely forget the H9s and then repairing.
Still left with an issue where my H9 max has access to the Pithfuzz, but the H9 core on the same account does not have access to it.
