Home Forums Products Stompboxes H9 and/or FACTOR PEDALS MIDI CAPABILITIES Reply To: H9 and/or FACTOR PEDALS MIDI CAPABILITIES
#146420
gkellum
    STMGUITAR wrote:
    1) will the eventide Boxes ( H9 or factor box) have a fully programmable Midi PC map? so that , for example, by receiving PC 1 from the controller i'll get preset 79 on the eventide???
    Yes, the H9 or Factor has a MIDI receive map which maps program changes it receives to a user selected preset or action (bypass, toggle tuner, etc).
    STMGUITAR wrote:
    2) Will the eventide box, AT THE SAME TIME, being able to send out a different PC to the line 6 M5?
    The H9 or Factor has a MIDI transmit map, but I believe that applies to MIDI program change messages that are generated when load a preset on the stompbox. I don't believe it supports remapping one received program change event to a different transmitted program change event.  (This functionality is described on pg 39 of the H9 user manual. https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf)
    Let me double check that…
