Home Forums Products Stompboxes Looking for help (chaining stompboxes) Reply To: Looking for help (chaining stompboxes)
#146446
Has anyone else experienced this? I am using mono cable for the entire signal path, and ensuring that I am using coordinating inputs and outputs (e.g. Input 1 and Output 1 to Input 1 and Output 1 of the second box).
Is it appropriate to route the signal from the first box directly to the second box? Does the signal need amplification at this point? What sort of amplification does that signal need once it has passed through two boxes? Could the amp that is driving the monitors be underpowered? I’m grasping at straws here.
The only thing left to consider is whether it has to do with the adapters I am using for the mono cables. I am using two 1/8″ to 1/4″ mono adapters becuase two of the cables are 1/8″ on one end and 1/4″ on the other. The cables and adapters are definitely mono (TS).
