Home Forums Products Stompboxes The new PitchFuzz algorithm is available for the H9 now! Reply To: The new PitchFuzz algorithm is available for the H9 now!
#146459
    Bodde wrote:
    mr. limbic wrote:
    I found something else that is a qualm though. Can any of these pitch parts be used as a whammy? Doesn’t seem like i can get 100% wet with any of them.
    No it can’t do that. There no wet/dry for the pitch. That’s the only thing that is missing. The dry signal is always there. Maybe Eventide is going to add that?. I like to use only the the high octave with no dry signal but it is not possible. Also for Whammy like things.
    From memory, but this should work:
    • PITCH AMT  –  2.0 through 3.0
    • PITCH B  (and / or PITCH C)  –  set interval to taste
    • DELAY LEVEL –  Arp Wet 100%
    • DELAY 1 (and/or DELAY 2)  –  0 mS [TEMPO OFF] or NO DLY [TEMPO ON]
