Home › Forums › Products › Stompboxes › The new PitchFuzz algorithm is available for the H9 now! › Reply To: The new PitchFuzz algorithm is available for the H9 now!
No it can’t do that. There no wet/dry for the pitch. That’s the only thing that is missing. The dry signal is always there. Maybe Eventide is going to add that?. I like to use only the the high octave with no dry signal but it is not possible. Also for Whammy like things.
Show More...From memory, but this should work:
- PITCH AMT – 2.0 through 3.0
- PITCH B (and / or PITCH C) – set interval to taste
- DELAY LEVEL – Arp Wet 100%
- DELAY 1 (and/or DELAY 2) – 0 mS [TEMPO OFF] or NO DLY [TEMPO ON]
Just tried this but it doesn’t work. The dry signal is always in the chain. When you set arp level to 100% (and delay off) there is no signal at all.
I wonder why the Pitch AMT is working in three stages? Pitch A,B,C is from 2.0 to 3.0. But you can just as well set pitch B and C off if you only want pitch A. So there is no reason to have a Pitch AMT in three stages? or am I missing something? What is the reaspn for the three stages? Maybe this ‘knob’ could better be divided in a wet/dry knob or something…
