Reply To: Harpeggiator: can not get it in time with beat
Home Forums Products Stompboxes Harpeggiator: can not get it in time with beat Reply To: Harpeggiator: can not get it in time with beat
#146515
mr. limbic
I’ve had the same problem in the past and my band plays to a click track so I’ve needed certain presets using the harpeggiator to be right on the money. Do you use an expression pedal? The only way I’ve found to “retrigger” is to set my expression pedal to control the mix (will have to check if any other parameters). If I go from heel to toe and land on the 1 then it’s always in time. Obviously this depends on how you are using it as you may not be able to do this for whatever riff your playing.
