Home Forums Products Stompboxes Can H9 be controlled via MIDI (cable connections) while the Control App is in use? Reply To: Can H9 be controlled via MIDI (cable connections) while the Control App is in use?
#146556
gkellum
    Bull Earwig wrote:
    What kind of hiccups should I expect?  Are there any plans to make things work smoothly?  All I need is for the H9 to select presets based on its program change map.
    Well, with what you're describing, I'd be surprised if you ran into any problems at all.  People have run into problems if they send the H9 a lot of MIDI data while simultaneously trying to use the app.  By a lot of MIDI data, I mean sending the H9 MIDI clock for example, b/c MIDI clock sends a device 24 ticks for every single beat, which can mean upwards of 50 messages a second.
