Home Forums Products Stompboxes Can H9 be controlled via MIDI (cable connections) while the Control App is in use? Reply To: Can H9 be controlled via MIDI (cable connections) while the Control App is in use?
#146558
gkellum
    Bull Earwig wrote:
    Do I understand that correctly?
    Yes, what you've said is correct.
    Bull Earwig wrote:
    So does that mean program changes made with my 3rd party midi controller will be reflected in the H9 Control app?  I.e., it will show what preset is selected?  I don't need it to go in the other direction; I just need the H9 to be a slave device that responds to MIDI program changes with its MIDI change map.
    Yes, if you have the presets screen open in H9 Control for example, the preset being shown will change as the preset on the H9 change.
