Home › Forums › Products › Stompboxes › Hiss Noise Mixing Link › Reply To: Hiss Noise Mixing Link
June 3, 2017 at 1:20 pm
#146570
Hi Yuri, how are you connecting to the mixer?
If you are using the XLR DI/LINE out, make sure this is set to the DI setting using the slideswitch on the bottom of the pedal. Also chk the mic gain switch on the MXLNK this may be set to 'high gain' when it doesn't need to be potentially adding too much level at this stage.
Can you email me more details of the actual I/O connectors you are using from MXLNK to the MIXER
thanks
