Home Forums Products Rackmount h8000 spdif Reply To: h8000 spdif
#146730
    sectiond wrote:
    hi, i tryed the spdif A>B setting but it doesn't work!
    In what way does it not work ?
    If you go to SETUP what do you see beside "Source" ?
    If you hit [clock]  what do you see ?
    sectiond wrote:
    i have the "EXT" led blinking under 44,1khz on the left of the h8000..
    This means that a routed input is unlocked – it may be one you are not using. The answers to the questions above will tell us if the SPDIF is the problem.
    sectiond wrote:
    and in logic i see only the output 11/12 spdif of the interface available and for  the input only 11/12 but not spdif.
    Don't understand this – I don't know Logic well.
