Home Forums Products Stompboxes Big Humm with expression pedals Reply To: Big Humm with expression pedals
#146780
    Je suis desolé, but it sounds as if you have a ground loop in your connections – this is beyond our ability to diagnose.
    Try using different cables, and re-arrange the wiring. Make sure things are only grounded at one place (no more, no less).
    If you cannot fix it, you will probably need to get a local technician to have a look.
