Home Forums Products Stompboxes SpaceTime Continuum [Preset List – 30] Reply To: SpaceTime Continuum [Preset List – 30]
#146798
leotio
    Brock:
    As you mentioned, I too think the problem is with the wet/dry mix, if you assign the exp. to control wet/dry mix, you can kill the effect on full heel, but will decay and not sustain when full toe, I messed chaging the valued on delays and fbk, and I get the effect in reverse but still decays. I think the solution to this is getting an exp pedal with X,Y control, which i dont have, but its still cool as is.
    Maybe a Kaoss pad? to which you could assign X,Y midi control, but you would control it with your finger instead of exp pedal, in the Matt Bellamy fashion.
    Scrap that! NOT routing a hole on any of my guitars! back to the drawing board
