Home › Forums › Products › Stompboxes › H9 as Whammy › Reply To: H9 as Whammy
July 17, 2017 at 7:26 am
#146800
OK Greg- lets get to the bottom of this:
a) does your expression pedal act normally in OTHER patches?
b) I am assuming you have the mission plugged into the Mastermind’s EXP input, and the mastermind hooked to the H9 by MIDI…true/false?
c) if true… what are your MIDI settings? (this question is intentionally broad)
—-if FALSE, what is your setup?
d) is there anything plugged into you H9’s EXP input?
e) if SO, what setting do you have under “General Settings–>Use Exp Pedal, Aux Switch, or Both”?
