Home Forums Products Stompboxes Performance switch & MIDI for MOD presets in H9 Reply To: Performance switch & MIDI for MOD presets in H9
#146803
pierrevdd
    camn wrote:
    I get totally normal behavior using my Arturia and the following MIDI settings, across all algos. “normal” being the same as my analog switch.
    MODE: Switched Control
    Option GATE (not toggle!)
    On Value: 127
    Off Value: 0
    I dont know if your pedal can do Gate mode.. but it should. If it can it will fix your problems!
    Hope that helps!
    Hey, thanks so much for this detailed and fast answer !
    I’ll give it a try tomorrow !
