Home › Forums › Products › Stompboxes › Pitchfactor Update Fails › Reply To: Pitchfactor Update Fails
July 25, 2017 at 2:57 pm
#146857
Disgraceland wrote:
Re: Power supply. Could this be a likely cause of the failure?
The power supply could easily be the problem. A weak power supply is the most likely cause of startup issues.
If you are not using an Eventide supply, I would suggest you get hold of one. If you are, it would be worth trying to borrow another one.
