Pitchfactor Update Fails
Home › Forums › Products › Stompboxes › Pitchfactor Update Fails
Viewing 3 reply threads
    • #114280
      Disgraceland
        Hi
        I can see that this is a known problem and I am posting here as i haven’t had any response from teh support email address (automated or otherwise).
        I have a Pitchfactor update failure.
        Initialy I tried to update to the latest version from a Mac (OS 10.12.05). It stopped at 75%, said that it had completed an dthe machine powered off.
        Now If I start the machine I get the single bar of lights, a pause for a few secpnds  then a full display of lights for a few seconds and then it powers down.
        I cannot perform system restore – same sequence of lights as above.
        I can only boot into update mode.
        I have tried updating to all versions of firmware availble in the updater.
        I also tried on a PC.
        To get it to work on a PC I have to run the H9 control software to get to the updater software. if I just try to run the updater as a standalone, it does not see the device.
        On a PC (Win 10 fully updated) the oldest update available (3.5 Ithink) gets the furthest  (100%), then said it was unpacking the software, said it had completed and then went off.
        I bought this unit second had and am conserned that the prices to fix seem more than the unit cost.
        Do you have a ‘special’ installer that will work on a Windows machine to force an update / system restore?
        Thanks in advance.
      • #146850
          I'm afraid it looks as though you have a hardware problem. This may be the reason that the unit was sold.
          Things to try before returning it:
          1) Update (yet) again, by whatever means appears successful.
          2) Following this, do a "Restoring Factory Presets and System Settings" as described in the UM.
          3) Consider trying a different power supply.
          If these fail, you should return it to your vendor, or send it in for service.
          • #146854
            Disgraceland
              nickrose wrote:
              I’m afraid it looks as though you have a hardware problem. This may be the reason that the unit was sold.
              2) Following this, do a “Restoring Factory Presets and System Settings” as described in the UM.
              Thanks for your reply.
              It’s worth pointing out that this was purchased from a friend and I know iit has worked well for him. It was working when I got it, I was just foolish to select the update option as I am not even sure it needed updating. The failure was directly caused by the update process – I’ve seen a lot of posts that all have the same type of issue, so I’m guessing that it’s not an uncommon fault?
              Anyway – I tried again. Slightly further this time:
              Attempted version 5.2.0[6] on a PC running Windows 10 fully updated. Note that I had to re-start PC before the H9 software would connect
              Started Pitchfactor in update mode. Screen says ‘Update…
              During process the following LEDs are lit:
              Diatonic
              Quadravox
              Harmodulator
              H910/H949 blinks aproximately every 2 seconds
              Update completed.
              Software lost connection with device.
              On the main screen I have 1 led lit under depth key, 2 lit to teh left of spped, 5 lit to the right of speed and 5 lit under Xnob
              I removed power cable, held down the Flex button and Tempo encoderr, plugged in power supply. Single bar of lights appeared, paused then a full set of lights (seem slightly dim) and then finally turned off.
              Any ideas? 🙂
              Re: Power supply. Could this be a likely cause of the failure?
            • #146857
                The power supply could easily be the problem. A weak power supply is the most likely cause of startup issues.
                If you are not using an Eventide supply, I would suggest you get hold of one. If you are, it would be worth trying to borrow  another one.
              • #146858
                Disgraceland
                  Thanks Nick. Will try that
              • #146865
                Disgraceland
                  Hi Nick
                  I now get the ‘Bad’ error.
                  Does this indicate Eprom failure?
                • #146866
                    This probably means that a preset did not load correctly. Try re-initializing. Otherwise this could be a failed update, a bad power supply, or some other hardware error.
