Home › Forums › Products › Stompboxes › Performance switch & MIDI for MOD presets in H9 › Reply To: Performance switch & MIDI for MOD presets in H9
July 27, 2017 at 2:09 am
#146879
Just figured it out on the leslie algo while setting the Helix to CC toggle. While the Performance switch is off you can double tap to toggle between slow and fast. if you hit it once you’ll toggle between Brake and off. you should go to the idea scale and vote up my suggestion to include momentary CC (or gate as above) so we can properly use the performance switch with the helix.
