Home › Forums › Products › Stompboxes › Performance Switch over MIDI with Helix › Reply To: Performance Switch over MIDI with Helix
#146898
Imerkat
    camn wrote:
    Imerkat wrote:
    So it does seem that H9 doesn’t support slow/fast over MIDI…
    I have to disagree. I have Fast and Brake working via MIDI, as described.
    Really? so if you hold it for long you get slow/fast and if you press it quickly you get brake from the same settings on your MIDI control? i’ve worked out as double tap CC toggle for fast/slow and once for brake
