Home Forums Products Stompboxes Performance Switch over MIDI with Helix Reply To: Performance Switch over MIDI with Helix
#146910
Really? so if you hold it for long you get slow/fast and if you press it quickly you get brake from the same settings on your MIDI control? i’ve worked out as double tap CC toggle for fast/slow and once for brake
[/quote]
Holy Crap that works!!   CC Toggle Dim value 0 and Lit value 127.    Just pressing turns on BRAKE.   But a quick on and off toggles FAST/SLOW.   Kind of different but that does work. Thanks for the help guys!!
