Reply To: No audio output when switching from bypass to active.
Home Forums Products Stompboxes No audio output when switching from bypass to active. Reply To: No audio output when switching from bypass to active.
#146950
Fuzzyblender73
Hi, my name is Massimiliano Atlantei
I have a problem with my EVENTIDE SPACE Serial number SP-11102 software version 5.2.oc6d
(mint condition), never used outside my house and never used that much.
Today I took my pedalboard and connected to the amp, but there’s no sound coming out of the pedal.
The pedal has its own adapter and everything works as usual – display ok, knobs working and number on display
changing when turning them, patches changing as always – but no sound.
I have a mono connection going from the end of the chain – last pedal is delay – to the amp.
If I disconnect the adapter the sound is ok.
I checked if killswitch is engaged and it is not. I tried to change the bypass mode but with both 3 options no way.
I also tried to connect the pedal to the effects loop of the amp but no sound.
Can you please help me?
Thank you.
