Home › Forums › Products › Stompboxes › No audio output when switching from bypass to active. › Reply To: No audio output when switching from bypass to active.
August 7, 2017 at 2:59 pm
#146952
Make sure that you are using Input 1 and Output 1 – my guess is that you are not.
If you are, set the unit to DSP bypass, and see if you get sound when not ACTIVE.
