Home Forums Products Stompboxes H9 Expression Pedal output through midi? Reply To: H9 Expression Pedal output through midi?
#146974
ref54
    Thanks a lot for the replies. I should have been thinking about the Midi Solutions…er…solution.
    I have an event Processor Plus that I have in-line after the first board (FA-06) to allow program change through, but stop note or mod & pitch bend to get through. So I reprogrammed it to also map CC11 to CC7. So the FA-06 gets CC11 (Expression), but the Prophet 6 and the Pro2 get CC7 (which they work fine with).
    Sometimes the answer is under your nose.
    Thanks again
    Derek.
