Reply To: Bluetooth?
Home Forums Products Stompboxes Bluetooth? Reply To: Bluetooth?
#147045
camn
there are so many ways.
there is a dial on the thing that you can use with your hand.
you can click a button and increment.
you can use AuX swithces.
OR you can use midi.
You can also program the thing, so that when you choose a preset on the H9.. it sends a signal over midi to the timefactor to switch as well.
It can be a simple setup using no actual midi controller.
Or, you can enter he wonderful and fantastic world of midi!
My setup just has a Disaster Are 3XL for control.
http://www.disasterareaamps.com/shop/dmc-3xl-gen3
Its small.. and I have three banks. The top button cycles banks… the front 2 are the active ones.
bank 1: our rotation, organized by song title. I choose the song, it sets up my H9 (it can control both the H9 and a timefactor simultaneously, tho),
bank 2: immediate activation up/down of presets.
bank 3: non-immediate up/down of presets. (I have to hit the button on the H9 to engage the change.)
I use the H(‘s right switch for tap tempo, and the left as on/off. I have an analog expression pedal (Mission) and analog AUX switch which is wired to the PERFORMANCE function. (which is totally key).
And seriously.. I am like 4 guitarists in 1. It is unreal.
