Home › Forums › Products › Stompboxes › Help – Trying to mimic a step-filter flanging effect › Reply To: Help – Trying to mimic a step-filter flanging effect
August 31, 2017 at 3:24 pm
#147075
dneilsen wrote:
… The boss es-5 has an automated virtual expression pedal which I can program to send midi CCs to the H9.
Check out this for reference if you like https://www.rolandcorp.com.au/blog/the-ultimate-guide-to-the-boss-es-5-effects-switching-system#ES5-48 …
I’d forgotten just how powerful that controller was. That triggered-type expression is something that I’ve feature-requested for the H9. Close to perfect for this kind of preset, controlled over MIDI.
Too bad it only transmits On / Off out the EXT CTL jacks. The H9’s expression inputs handle incoming data a bit more smoothly (understandably so), and there are a few more routes for per-preset variations.
If you can give me until the weekend, I’d like to put together some options for you. When I listened to the clip on some “real” speakers, it gave me a few more ideas (like pulling it off in-preset, without external MIDI). I’d also like to compare expression pedal control against a similar waveform over MIDI.
As it stands right now, I’m still thinking the Octaver algorithm. I’ve gotten some unique results from that set of ‘squawky’ resonant filters. Here’s a ‘handwritten’ example, from more than 4 years back:
