Home Forums Products Stompboxes Help – Trying to mimic a step-filter flanging effect Reply To: Help – Trying to mimic a step-filter flanging effect
#147131
brock wrote:
Here’s what (I assume) you’re sending over MIDI:
yup. That’s pretty much it.   I can also use a sine, triangular or square wave form as well to generate the midi change
brock wrote:
Quick question:  Can you use both the expression pedal “thru” and the automated output from the ES-5 at the same time?  I assume that you’re using the Wave option.  My thought was that – instead of using a Ramp output – you could use a Square Wave to provide the steps.  The smooth ramp up would have to come from elsewhere.
Those were my initial ideas.  I still have a lot to try out, using the other algorithms.
If i move my manual expression pedal its change does register but it is immediately overridden by the midi expression pedal signal.
but…  i just had a thought
The boss es5 can send up to 8 midi signals per patch so i am not limited in that regard and i have noticed that the controls in h9 control can be bongs to the expression pedal or A B and C controls.
I wonder if i can send a midi control to automate A B and C?
If so in theory i could have 4 automated control sets
Thanks for the patches above.   Ill try them out today.   Ill also test if i can Bind to A B C and let you know.
Stay safe with the hurricane mate.
We are getting some coverage here and it is not pretty.
